Bluetooth Error on ZenFone Max Pro M2
ZF Model: ZB631KL
RAM: 4G
Firmware/APP Version: 15.2016.1812.179
Frequency of Occurrence: Always
Rooted: No
APP Name: Bluetooth
Last edited by HerbertEndrian on 2019/1/16 20:31 Hi ASUS, today, i'm facing problem on "Notification Bar". As we can see in the Screenshot, I didn't turn on my Bluetooth, but in my notification bar, the Bluetooth notification is still enabled. I sure this is Android Oreo bugs, because, when I use ZenFone Max Pro M1 (ZB602KL), i didn't facing the problem, so please fix this As Soon As Possible :D Curenntly, I am using : Zenfone Max Pro M2 (ZB631KL) ; with firmware : 15.2016.1812.179-20181221
9 REPLIES 9
verydiaz
Sepertinya normal gan, sy test di FW 179 juga bluetooth bisa disable/enable
vrydz posted on 2019/1/17 15:08 Sepertinya normal gan, sy test di FW 179 juga bluetooth bisa disable/enable
Enable / disable mmg bisa gan, tapi di bagian notification bar error
kychame
HerbertEndrian posted on 2019/1/17 19:44 Enable / disable mmg bisa gan, tapi di bagian notification bar error
di saya enable disable gak ada notif error sih.. baik itu bluetooth karena sering pake earphone bluetooth pas gym.. juga do not disturb sering enable disable jg kl maen pubg,, sudah coba clear chache partition lewat stock recovery?
siahiese
Hallo Asus..., Bluetooth ane bisa terima file tp kok ga bisa kirim ya. Thx 😊
baghoezt1001
Hi asus kenapa ya headset bluetooth saya kalo muter Youtube ,Facebook ,WA story ,dan sosmed yg laen suara di hp juga ikut keluar..tapi kalo muter media player MP3 sama media player video normal...
