BATTERY DRAIN IN MAX PRO M1 AFTER 082 UPDATE
bhaveshsuthar23
Model Name:asus max pro m1
Firmware Version:082
Rooted or not:not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):Battery drain issue
After update in max pro m1 . The device battery is drain in ideal time from 50% to 24% . The battery drain is not optimised and in normal uses also drain very quickly compare than 063 build . In 063 build i was got 8 to 9 hour screen on time use and in 082 i got 4 to 5 hours screen on time plz fix it asus developer . Provide native video calling , airtel wifi calling , enable camera 2 api also the asus team what is doing
1.battery drain in ideal and normal use
2. Fingerprint scanner not optimised it is not responsive
3. Double tap to wake up not working properly
5 REPLIES 5
pvkrishnanunni
Yes I'm also facing battery drain in idle condition. Network standby is draining the battery
Rameez221
I am also facing the same problem
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
Please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
Recalibrate battery
To recalibrate battery, charge your phone to 100% without interruption.
then discharge it normally till 0%(phone gets switched off).
charge it to 100% in switched off condition and keep it in that state for a little more time.
now switch on your phone in charged condition and unplug when ASUS logo appears.
keep the phone unused for 5 mins.
you will get far better battery life as the battery stats.bin file will be updated.
Hi I am facing same issue ☹️
Battery is drain even in idl condition with data off
