Asus Zenfone Max Pro M2 stuck on asus logo suddenly
patssushil
Rising Star I
Model Name:ZB630KL
Firmware Version:Latest .73
Rooted or not:Not Rooted
Frequency of Occurrence:From sunday onwards
well i was using my asus zenfone max pro m2 as always,then suddenly it swiched off and when i tried to turn it on from then its not moving from the asus logo screen
for troubleshooting i tried to wipe catche partition but the recovery mode is not working , whenever i try power button along with volume down button, still phone shutting down and again its stuck on the asus logo screen
kindly fix this issue asap cause its so annoying and i am not able to use my phone completely beacause of it
349 REPLIES 349
saeed121
IFinally i found the problem...with solution..the solution ..is we have to pay to technician for Rs 2000 ....then they will replace our emmc and fix it ...2 nd solution is through UFI Box with I S P method emmc format....2nd solution comes with Rs1000 ...one of my friend has just fixed it through technician..they took Rs 1500 from my friend as a charge to fix it...The problem occurs die to 0.73 OTA Update comes with bug which has blocked the partition of our emmc ..thats y we cannot flash it....Hate on you Asus...I would never recommend anybody to buy the asus products...it comes with so many bugs.....so do not wait those who had already been out of warrnty go to technician and fix it...And wait those who still are in under warrnty....
And Asus service centre only they have the solution by replacing with new one motherboard...coz they dont use ISP and UFI Method ...so they will fix it by change the motherboard...
Nilesh13
Brother can you explain it in detail the second method
Nilesh13
And where are you from
saeed121
Nilesh13
In second method...it can be fix through UFI Box and A jumper Adapter which is used to connect with I S P method..bro if are a technician do it...but if u are not...then u should visit to technician to fix it ...they open ur phone back cover and I S P pinout through the technician will reprogramme your emmc..its Embaded Multimedia Card...
saeed121
Nilesh13
Mumbai maharashtra Borivali..
