Asus Max Pro M1 Can't update android 10 beta 3
Please tell me why I can't update firmware android 10 beta 3
ZB601KL
Firmware version WW_Phone-16.2017.2005.082
7 REPLIES 7
Christine_ASUS
Hi สิทธิพงศ์
Thank you for your reply. Please refer to the steps below
1. Try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
2. Download V429 file via PC
3. Put the image file into the root directory, the outermost place, of the MicroSD card
4. Tap pop-up notification (p.s. if the notification doesn't come out, try re-boot)
If the situation remain the same, please provide me a video of your firmware update process.
I got it thank you for your help. I'm done on Android 10
Minku
Android 10 3 beta gcam potred mod not working 😡😡battry bekup not good
Really!!! I think my battery is good for android 10
Christine_ASUS
Community Legend II
Hi Minku
Thank you for your asking. Sometimes the battery drain after firmware update may cause by some disturbances from the installed 3rd party apps. Please try the Factory Reset.
