Asus max pro m1 android 10
milantailor254
Model Name:ZB601KL
Firmware Version:424
Rooted or not:no
Frequency of Occurrence:
I've updated to Android 10 yesterday and it's a very good update.
The battery life is great and good backup
Wifi calling is active as you can see in screen short
The gesture is working perfectly and there are no lags since update.
No heating issue and charging time is same and lil bit improve I would say.
Force dark mode is perfect in work.
Sound is too good but it does cracks if the volume is full, full volume isn't even necessary in medium level sound is great trust me.
For basic and daily use it's the best update.
Don't listen any rubbish about it trust me it's good!!🙇🏻
36 REPLIES 36
ZT-80a35633
Notification sound very low.
bk817651
Model Name:ZB601KL
Rooted or not:no
Device name: Asus zenfone Max Pro m1
How to fix large navigation bar bug please help me please please please.
bk817651
bk817651
  1. Model Name:ZB601KL
  2. Firmware Version:424
  3. Rooted or not:no
  4. Device name: Asus zenfone Max Pro m1
Just make display size to default and go to developer option and set smallest dp width to 400. It will now be fixed and not change the display size
Vishal_Sharma
satyamgupta01
When the update will arrive to India?
Never.
HitoNicK
since Android 10 has also arrived on the max pro m1, when will it be released on the rog phone 1?
