Monday
Hello all, recently my phone hasn't been charging with anything other than fast charging (USB C to USB C).
After years of using USB A to USB C chargers (regular charging speed) my ZenFone 9 just loses battery as if it wasn't being charged when plugged in. The phone still says it's being charged when connected with that wire, however the battery doesn't go up (even with no apps running and turning off a bunch of background services). This is especially annoying as I can't charge with a computer or my power bank anymore.
I know there have already been some posts about this issue, but I haven't been able to find a solution from them so I thought I'd try and see if it's fixable. I've already tried cleaning the port, restarting, and tried a bunch of battery charging settings (steady charge on/off, etc).
My ZenFone is currently running the latest Android 14 update and is not rooted.
Would really appreciate any help on this.
Thanks 🙂
Tuesday
Hey @newbiemelody,
Do you experience this issue while using a specific charging cable or adapter?
Also, can you please share a log for this issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Tuesday
Hi Mansi, this issue happens with any charger that is not USB C to USB C (i.e chargers with a USB A port for output). I've tried several chargers and cables and have the same issue if the output is via USB A. Interestingly, my battery pack has both USB A output and USB C output; doesn't charge using a USB A cable but is fine with C. I noticed this issue started occuring sometime after I recently started using the Asus provided charger (which is USB C output). Not sure if this is coincidental or not.
I'll share the logs with this issue occuring soon.
Thanks for the reply
