ZenFone 9 getting very hot and battery draining
BZH
Model Name: ZenFone 9
Firmware Version: 33.0804.2060.189
Rooted or not: Not rooted
Frequency of Occurrence: Daily
I have found recently that my phone gets really hot (especially on the left side, towards the top) at all times.
This happens at al times when I am both using and not using the phone. I have killed all apps and restarted my phone multiple times.
This is also causing my battery to drain very fast.  I am lucky if the phone lasts 10hrs before running out. I can lose 30% in 2 hrs sometimes
Mansi_ASUS
Hey @BZH,
Can you please share a log file along with the battery usage screenshots?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
BZH
Hi @Mansi_ASUS
Thank you for your reply.  I have the log files. Do I need to send them provatly across, or can you confirm that there is not personal/sensitive data in the logs?
Thanks
Bryan
