Zenfone 9 Camera Problem
ferizan
I suddenly have this issue on Zenfone 9.
Whenever I open camera, it's lagging. even when I move my phone a bit, it's lagging again. I dont know what's happening right now.
Frustrating whenever I want to take a picture of something
#Zenfone9 #Camera #ZenfoneCamera
24 REPLIES 24
Hi, yes.
the camera in third party apps works
The camera works with third-party applications
In mine - not
Mansi_ASUS
Hi @ferizan
Can you please share a log for the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
