05-21-2024 12:00 AM
I suddenly have this issue on Zenfone 9.
Whenever I open camera, it's lagging. even when I move my phone a bit, it's lagging again. I dont know what's happening right now.
Frustrating whenever I want to take a picture of something
#Zenfone9 #Camera #ZenfoneCamera
2 weeks ago
Hi, yes.
2 weeks ago
the camera in third party apps works
2 weeks ago
The camera works with third-party applications
a week ago
In mine - not
06-11-2024 04:27 AM
Hi @ferizan
Can you please share a log for the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
