Zenfone 8 Android 12 Beta, System UI stopped
boygrizell
Model Name: Zenfone 8
Firmware Version: 31.1004.0404.68
Rooted or not: Not Rooted
Frequency of Occurrence: a few times a day
APP Name & APP Version (If your issue relates to the app): different apps
After installing, having problems with System UI on a daily basis, it stops.
After closing, everything works properly, but it doesn't solve the problem.
It occurs with YouTube, Google Maps, etc.
For instance, when viewing a photo and turning the phone horizontally sometimes you see black linings occur , like the "camera-opening/hole", in the picture. Then after a few moments System UI stops.
I can't make a screenshot of the problem, because that doesn't work when System UI stops 😉
15 REPLIES 15
mr_deens
Rising Star I
boygrizell
Hi, yes, still having the same problem.
System UI crashes daily, even after the latest update.
Mostly it crashes after switching to landscape modus while watching movies or while switching between apps in landscape modus. Also there is a black curve visible. The curve of the phone's screen. Can't post a picture because that isn't working when System UI is going to crash.
After shutting down System UI, the system returns to the app which I was using.
You still on beta or official version?
bobwilson5k
I am also having this problem and finding it difficult to report the issue to asus.
boygrizell
I'm on version 0404.81
daniel91m
Rising Star II
boygrizell
I have the same problem, I also use the latest software version
Zen8HK
I'm also using Zenfone8 Malaysia set. As per my experience with the System UI, it does crash when changing to landscape mode. But recently I've changed my default launcher to Nova Launcher and the problem disappeared. I think the bug is in ASUS default launcher itself.
