Smart key for flashlight not working
jim_olsson_se
I have set up the Smart key for pressing the power-button twice to turn on/off the flashlight, but this is not working from a locked screen, but It works when the phone is unlocked.
When I press it I get the error message "Flashlight is currently unavailable", but if I use the flashlight shortcut in the notification menu it works (while in locked or unlocked mode).
This worked before but after some update it stopped working.
12 REPLIES 12
Timo_Vos
Rising Star I
This seems to have been fixed (in my case with the camera).
Is it also fixed in this case?
jim_olsson_se
Timo Vos
No, the same problem with flashlight is still here (using the latest update).
Anders_ASUS
Hall of Fame III
jim.olsson.se
https://zentalk.asus.com/en/discussion/comment/173256#Comment_173256
Unfortunately this limitation will always be there as I reported the same issue before ZenFone 8 was released. CH has already stated the reason above. But there's another limitation/bug that works like a workaround that ASUS hasn't removed. If you press the power button multiple times, then there's a good chance that the flashlight will turn on anyway. It doesn't work every time but it will most times 🙂
