Issues with the Zenfone 8
shlomiu
So I've had this phone for about 2 months now , there are a lot of software issues that really detract from the overall experience.
Pocket proximity - I know that there were an update that was supposed to improve the pocket detection , but for me the phone consistently keeps turning on in my pocket. this causes it to lock down after multiple failed fingerprint scanner attempts (inside of my pocket), which is ANNOYING AS HELL.
Lockdown slowness - whenever the phone "locks down" (due to too many attempts at unlocking it unsuccessfully) , the phone slows down to a crawl.. when I'm trying to input my password it seems like there's a 2 second delay from the moment I touch the screen to the phone actually registering the touch. it seems to only happen when the phone has been attempted to get unlocked too many times.
Random microphone failures - sometimes when having phone calls my microphone seems to stop working and the other side can't hear me, the only way to fix this is to restart the phone.
(Hardware) overheating issues - this phone is overheating like hell.
Slow camera - the camera is slow as hell at taking and processing photos , it seems it takes the phone 3-4 seconds to process the photo after taking it.
Aggressive RAM management - I have the 16gb variant , and even with all of this RAM the phone keeps killing apps.
Overall I like the phone, but the software could be better and that's 50% of the experience.. I hope this gets fixed.
5 REPLIES 5
Iceman11
Yes, it's still not working well. Workaround that I use is to disable "screen off unlock" from settings ---> Security & lock screen ---> Fingerprint ---> Unlock device (click on it, not on the switch) ---> screen off unlock (turn it off). This way to unlock the screen we have to first enable the screen from the power button. It's not that annoying when you get used to it. But, Asus should have gone with side or back mounted fingerprint sensor.
Haven't noticed that. The last few updates greatly improved the finger print sensor and now I'm getting pretty good accuracy. Maybe more thant 90%.
Never received complaints about that from the other side.
Yup, while gaming it's getting pretty hot as most of the other phones with Snapdragon 888 SoC.
What I noticed, camera takes more time to process the photo when you're taking 2x zoom photo, because it's implemented by croping the main 64 MP sensor to 16MP. Haven't noticed issues or slowness while taking normal photos.
Yes, the default one is not good. It's making the phone to work as you don't have enough free RAM. From settings ---> battery ---> System modes ---> advanced you can disable "Force restriction to background CPU usage" and it solves the problem.
