fix raw buffer resolution limitation
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-07-2021
03:32 AM
- last edited on
01-16-2024
01:41 AM
by
ZenBot
Can you please fix raw buffer resolution limitation like you recently fixed on Rog Phone5?
Thank you
Thank you
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-12-2021 09:33 AM
Yes please, this phone need that fix for more sells 😉
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-18-2021 01:16 PM
Good day,
Please next update, can we have the buffer fix working? The rogphone has already 😕
Thanks you
Thanks you
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-19-2021 02:03 AM
Merged two threads, there is no need to create new threads.
You might want to clarify what exactly you are requesting.
There is no resolution limitation bug on ASUS camera.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-21-2021 03:35 AM
CH_ASUSWhat happen is gcam tried to use 64 mp raw buffer but it was limited by raw buffer resolution at 5488*4112 (around 22 MP) from usecase. This applied to every sensors on the device so if request raw resolution is greater than 22 MP the usecase will return null as it can't match resolution.Merged two threads, there is no need to create new threads.
E/CHIUSECASE: [ERROR ] chxusecaseselector.cpp:411 DefaultMatchingUsecaseSelection() Failed to match usecase. pSelectedUsecase is NULL
E/CHIUSECASE: [ERROR ] chxextensionmodule.cpp:4024 InitializeOverrideSession() For cameraId = 3 CreateUsecaseObject failed
This BUG is already fixed od Rog Phone 5
