BIG BATTERY DRAIN ON ZENFONE 8 ON ANDROID 12
Vanja1986
Tge battery on my zenfone 8 is draing so fast ni matter what battery mode i use. Im mostly on dinamic and auto refresh and AOD OFF. The battery life is alos very inconsistent. Just using the phone drains the battery very qiuckly. I dont play games on it,aslo the camera app is using alot of battery. Any advice??I just hope they fix this issues with next updates. Eveything else i love on this phone.
26 REPLIES 26
Vanja1986
andreescul
https://zentalk.asus.com/en/discussion/comment/207830#Comment_207830
Did you factory reset?
Yes. Its better now. Gues phone had to settle.
hllsynotebook
Rising Star II
Never charge the battery to 100%, this will cause great damage to the battery. Set a charge limit of 90% and remove it when 90%. Your way of using the charger is very wrong, the battery needs to be changed
