[Issue] Phone freezing + bedtime doesn't turn off itsel
rogalot
Model Name: Zenfone 7 Pro
Firmware Version: latest from Asus
Rooted or not: not
Frequency of Occurrence: daily
APP Name & APP Version (If your issue relates to the app): N/A
Hello,
First issue - since the last or last 2 patches before my phone very often freezes when I'm trying to push one of the 2 buttons below - the circle (get back to the main screen) or square (see all open tabs), does anyone else have this issue? It freezes for like 5 seconds, if I double tap the square it takes a screenshot as it should, also I can press the triangle button for "back" and it works.
The second issue - the bedtime feature doesn't turn itself in the morning. I set it for 6:30 AM and it never turned off. I tried it many times.
miguelsmatos
Sounds like another part of a poor software implementation; I'd try resetting it. If that doesn't work, it's probably just another bug.
They call them ZenFone but there's nothing Zen about them; it's more of a BugFone.
