05-17-2020 04:05 AM - last edited on 01-16-2024 01:09 AM by ZenBot
05-17-2020 11:03 AM
shiv1gI almost exclusively use 2A chargers (there are 4 that I typically use in various places at home and work). Usually I get between 1100 and 1700mA depending on how I use the phone while charging. I have used a few 2A chargers that only gave less than 1000mA (one was a Belkin charger). I just blamed it on those chargers. But if you want different results you would likely have to experiment with different cables and chargers. I've had great experience with Anker and Aukey chargers.I have mine set to 10 pm to 9 am.
I use a normal 10W charger (18W in-box fast charger makes phone hot and degrades battery health). For me, the battery stops charging at 81% and reaches 100% in between 8.00 to 8.20 am always.
Also, even though I'm using a 10W(5V 2A) charger, the Ampere app only shows a maximum of 950mA current, which means it only charges at 5W max. The cable I'm using supports fast charging.
Can anyone explain to me why? Shouldn't it be charging at a higher current, somewhere around 1800mA?
It takes 5 hours to recharge my 6Z for dead to 100% using a 10W charger. If 6Z starts supporting the full potential of 10W charger, it can definitely recharge to full within 3 hours.
05-17-2020 11:19 AM
skylerwolfeI'm using Sony, Samsung, OnePlus and Vivo 2A chargers with OnePlus dash cable and Asus original cable. All i can get is a maximum of 950mA current. Please give me the names of the chargers that give you more than 1500mA current.https://zentalk.asus.com/en/discussion/comment/80835#Comment_80835
05-17-2020 11:55 AM
05-17-2020 12:06 PM
05-17-2020 01:02 PM
skylerwolfeOk. So, 6Z can only charge at 1000mA max with a regular 10W charger. That's interesting!At this moment I'm using this charger. I should note when I said 2A charger earlier, they are probably all actually 2.4A.
https://www.amazon.com/dp/B013US9FFY/ref=cm_sw_r_other_apa_i_tGyWEbCKZC08C
