Battery Drainage issue after android 11 update (Already Factory reset)
panup310
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
In addition to the information above, please also provide as many details as you can, e.g., using scenario, what troubleshooting you've already done, screenshot, etc.
After the android 11 update battery is draining so fast and in battery usage android system is taking 15% and I have done already factory reset after the upgrade
lokesh_k0904
Rising Star I
Yes facing same after .127 update
lokesh_k0904
Rising Star I
@Anders_ASUS plz fix it
victor010
Zen Master III
Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying the below:
1. Charge the battery to 100% & use as per your normal usage pattern
3. settings => Battery => Check the screen & share the same
Also, follow the below steps may improve battery backup:
1. Enable “Power saver” (Settings > Power management)
2. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
3. Adjust sleep time and brightness (Settings > Display)
4. Boost memory when you see memory consumption is high with no app running,
5. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
