Audio effects
durv1503
I ve Asus 6z. It doesn't supports special sound effects (i.e.8d) sound effects on videos over youtube. At first i thought it may be problem of headphone jack but when i bought wireless headsets i realised that the audiowizard software prevents the effect.please do something over it
20 REPLIES 20
jithin_pattambi
Rising Star I
it works perfectly with me.. i mean the 8d(sound panning) effects on both speaker and headset.. Sometimes terrible is slightly high on ear peice side when playing such videos..
durv1503
No those effects aren't working i used all types of settings in audiowizard effects aren't provided
Nanni
Just check if you have enabled mono audio
Settings>Accessibility>Audio and on screen test and switch off the mono audio.
Hope it helps
prashanth
Rising Star II
nishaanth5000
https://zentalk.asus.com/en/discussion/comment/24673#Comment_24673
Which earphone did u use
The one that they gave in the box
durv1503
Nanni
Hope it helps
Ya it helped thanks my issue is solved
