03-10-2021 12:35 AM
03-10-2021 12:46 AM
03-10-2021 01:57 AM
vicky9943861292What....?? are you serious! This is 2.7 years old device and you cant see notification LED for other apps??...Please tell us some basic information before asking for help:
- Model Name: 5z
- Firmware Version: November patch 2020
- Rooted or not: not
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
I want led notification for other apps notifications . Why asus didn't do that ?
Is it possible through updates ?
Why 5z have Notification led for only charging ?
03-10-2021 07:21 PM
AmitGardeIt's already turned on . But never seen glowing led on other apps notificationshttps://zentalk.asus.com/en/discussion/45564/why-5z-have-notification-led-for-only-charging
Notification LED is supported for other apps. if it is not working for any specific app than try to go and check with settings of that app and you should see notifictaion LED option there ( but remember 5z is supported only with 3 colors i. E. Green, Red, Orange)
Thanks!
03-10-2021 07:36 PM
vicky9943861292Tnxxx i got it .https://zentalk.asus.com/en/discussion/comment/156192#Comment_156192
