04-16-2020
09:26 AM
- last edited on
01-16-2024
01:08 AM
by
ZenBot
05-11-2020 11:28 AM
ARP_ASUSShouldShould all of us visit the service centre as all of us would be having a hardware issue??I would suggest once the lockdown eases kindly visit the service center.
As you have tried all the possible troubleshooting. Also, I will try to check the same. Thanks.
05-21-2020 11:49 AM
06-05-2020 02:30 AM
Chintan DevganiyaDoes the screen turns off completly when you double tap the screen when turned off?Well i have tried just now and I'm not having this issue. When i try to lock the phone by double tapping the screen doesn't go off just phone is locked. I have to lock phone by physical lock button to turn the screen off. It goes completely black not like you mentioned in 1st photo.
06-05-2020 02:32 AM
06-05-2020 02:33 AM
aamod.v8Who said? Ki kisi ko ni hai. Mere cousin ke phone me bhi exact same problem hai. And btw jinhone btaya bhi ni hai agr problem to wo log bhi khn video bhej pa rhe hain?dekh lo bhai almost no one is having this problem. maybe there is problem with proximity sensor. Service centre is only solution. else send your phone log to mods.
