Sound is not balance on both channels(Asus zenfone 5z) while connected to bluetooth earphones.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-17-2021 04:55 PM
When I listen to the song from my OnePlus Bluetooth earphone, The right chhanel sound is much louder as compared to left channel. I also try to other bluetooth earphones but same problem occurs. I also do the reset my phone but Notting happened. How to fixed this issue.
Phone model: Asus zenfone 5z (Z01RD)
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2021 08:20 AM
Hi, Please try the troubleshooting tips below:
1. Please try reset Network: Settings>System>Reset options>Reset Wi-Fi, mobile & Bluetooth
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
3. Also, please try "the Factory Reset" after backing up all the data.
Settings>System>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
4. If the issue persists after troubleshooting above, please check your SMMI test: Calculator> type ".12345+=">SMMI TEST>Bluetooth
If any of the SMMI tests fails, indicating the high possibility of faulty hardware, kindly bring your device to the nearest ASUS repair center for device checking: https://www.asus.com/in/support/Service-Center/India
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-19-2021 09:41 AM
Thanks man.. Now working fine
