11-24-2020 01:56 AM
Solved! Go to Solution.
12-02-2020 09:16 PM
12-05-2020 05:24 AM
12-11-2020 11:20 AM
xbms@xbms . How can you say that "Let us hope that ASUS will fix this on their next update" lol😂😅🤣. You dont know there are lot of bugs still need to be fixed that came along with the initial asus android 10 os update. You can see lot of people complaining of the same thing, still asus hasn't fixed it. They release update stating that that so and so bugs are fixed but actually they have created another bug and we people report it here and some moderators says that they reported it to asus. Either asus listens to it or ignores it as usual. if asus listens to it the above said bug fixing update cycle continues. Actually this is a trap they make our phone useless with their buggy os updates and force us to buy new device. Opting asus was a big mistake.@rahulraghuram172 Iam also on latest version [WW-100.10.107.110]. Yes as you mentioned this problem is also on the current version of update. Let us hope that ASUS will fix this on their next update.
12-12-2020 08:52 AM
12-12-2020 09:28 AM
Chintan DevganiyaI tried doing the same thing as mentioned in video and I'm getting same results. I think the problem lies with the proximity sensor.
When you double tap on home screen while on calls screen locks and not goes off. When you lock the screen by tapping power button screen turns off and device locks but when you put your hand on the proximity sensor and take it off screen truns on. Usually this shouldn't happen. When device is locked proximity sensor should turn off but insted it remains on until you finish your call irrespective of the methods you use to lock your device
