- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-24-2020 01:56 AM
Model Name: ZENFONE 5Z ZS621KL
Firmware Version:WW-100.10.107.99
Rooted or not: NO
Frequency of Occurrence: ALWAYS
HI... Iam using zenfone 5z ZS621KL [Indian version ] for almost two years. It was running fine until the latest update WW-100.10.107.99. Whenever I call someone if I have used the proximity sensor for once and then turn of the display by DOUBLE TAPPING during the call, My phone's display will not turn off, instead it goes to the lockscreen and then the whole display become unresponsive. If I use power button instead of double tap to turn off the display this issue will not occur.
For information
- I didn't dropped my phone since I bought it.
- My phone's display is working fine but goes crazy only during above said scenario.
- My phone's proximity sensor is working fine as it should be.
-I have done hardware reset thrice for this issue.
I have added a video footage of this issue along with this post. From my point of view its a software bug. All others who are reading this post and have zenfone 5z on current version of update, Please check and give your response and if anyone is having a solution for this issue will be much helpful.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-26-2020 12:07 AM
the screen won't sleep when it is unresponsive
Do you mean the "unresponsive" in (2)?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-26-2020 12:38 AM
Christine_ASUSHi..@Christine_ASUS. I have gone through your reply and your steps 1 and 2 are correct. May be this issue was present in v92. But now only Iam noticing it. As @adityapruthi2001 mentioned in his comment that the display is not sleeping while it is not responding. Yes whether you are on step 1 or step 2 doesn't matter the display will not sleep or respond until the call gets disconnected. Everything will become normal after the call gets disconnected or You have to press the power button multiple times during the issue.Hi friends
I just tried again about the function in V92 and V99. Both versions have the same reaction, does the behavior appear right after any system/apps' download or update?
(1) Block the Light Sensor>back to home>double tap to turn off the screen>the device can not swipe up to unlock, click power bottom will active *swipe up to unlock
(2) Block the Light Sensor>back to home>double tap to turn off the screen>swipe down>Settings>unlock>Settings panel stuck.
Does aforementioned passage correctly describe the situation?
Thank you @archilsoni412 ,@1947msr ,@amitgarde3 ,@Debasish Sahoo ,@adityapruthi2001and @Christine_ASUS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-26-2020 02:03 AM
Let me check with the relevant team. We will keep you updated and your consideration will be very much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-26-2020 11:41 AM
Christine_ASUSYes, i mean unresponsive.the screen won't sleep when it is unresponsive
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-28-2020 04:47 AM
Christine_ASUS@Christine_ASUS thanks for your reply and we have high expectations on you. We hope that this issue will be fixed by next update and thanks for all who have replied to my post.Hi friends
