Hi
dausburn8Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
1. Is your current firmware version WW-100.10.107.110?
Settings>System>About Phone>Software information
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
https://www.asus.com/support/FAQ/1005163/3. Does the situation remain the same with other adapter and cable?
4. If the issue remains the same in "Safe Mode", please try "the Factory Reset"
Settings>System>Reset options>Factory data reset
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
5. Is there any zone heating up while using/idling? How long has the battery been used?
If the situation remains the same after performing the Factory Reset, please contact ASUS repair center in the country of your residence for the battery checking:
https://www.asus.com/support/Service-Center-All-Countries/If it is impossible to access the service center during Covid-19 period, please try Call us:
https://www.asus.com/support/CallUsFor more information, please refer to the links below
https://www.asus.com/support/FAQ/1009546/https://www.asus.com/support/FAQ/1009547/
