05-22-2020 10:50 PM - last edited on 01-16-2024 01:08 AM by ZenBot
06-03-2020 08:22 AM
Anders_ASUSThankyou,Agreed to ur explaination and will require sometime to test ur advice 😊No one will believe me if I say that the battery life is the same in A10 as in A9, so who is willing to factory reset their phone, run three sets of PCMARK and then downgrade to A9 and do another three sets so you can tell everyone that there's actually no major difference?
Maybe one is slightly better than the other when both are factory reset but we're talking a couple of % in difference, not 50%
06-03-2020 08:32 AM
Anders_ASUSYes sir there is not much major difference in battery % in compare to A9 but in A10 I feel a little bit more battery drain bt I think this may be due to battery health as battery is getting old and its almost 2 years so this may be the reason behind the extra battery drain.No one will believe me if I say that the battery life is the same in A10 as in A9, so who is willing to factory reset their phone, run three sets of PCMARK and then downgrade to A9 and do another three sets so you can tell everyone that there's actually no major difference?
06-03-2020 08:34 AM
06-03-2020 08:42 AM
ramneek2110Are you talking about fast charging isnt visible on lockscreen? Or not even normal charging is happening with asus charger?The main point of this thread was 1) battery drain. That has been explained by the Mod.
What about the 2) Not recognising the charger? Enlightenment on this issue too??
06-03-2020 08:47 AM
amitgarde3Not charging at all let alone fast charging.https://zentalk.asus.com/en/discussion/comment/86079#Comment_86079
