ROG 2 - Slow charging/charging issue
Model Name: ROG 2
Firmware Version:
Rooted or not:
Frequency of Occurrence:
My phone doesn't charge fast, there is no problem with the charger and the cable.
Taking an hour or so for 10-15 percent.
Don't know what the problem is, having the issue since two days
Any help would be appreciated,
Thanks in advance!
6 REPLIES 6
@Gustav_ASUS and @ARP_ASUS ,
Thanks for the suggestion, tried with a new charger[one plus] and it's charging well.
Used AccuBattery application for reference-tells you the charge current, speed, voltage, etc.
Thought there was a problem with the adapter[charger] and was thinking about buying a new one, luckily interchanged the cables and found that problem was with the cable and not the adapter.
Gustav_ASUS
Community Legend III
@chintulakkimsetty Glad to hear you found the root cause!
