Powermaster Help please
ishaan_gupta10
Powermaster is terminating my app in background even after I have disabled all the settings. Even I have set app' battery optimisation to 'not optimised' . Attaching some snapshots of the settings. Please help me and tell if there are more settings i need to do. Its really annoying.
14 REPLIES 14
ishaan_gupta10
ronald1985
https://zentalk.asus.com/en/discussion/comment/107301#Comment_107301
Thanks for this. I haven't yet reproduce the problem yet. At the moment, the app has been running for over an hour.
Do you have the latest firmware installed?
Also, do you have any battery saving apps installed, such as AccuBattery?
Happened again. Check the snapshot and video.
ronald1985
Community Legend I
ishaan.gupta10
https://zentalk.asus.com/en/discussion/comment/107327#Comment_107327
https://us.v-cdn.net/6031231/uploads/1LGAF1M7FDRA/2020-08-29-18-11-35.mp4
PowerMaster still seem to be on in detecting apps even though you have it disabled. For now:
Can you go to Settings - Apps & Notifications - See All Apps - Press on the 3 dots and go to PowerMaster
Press on Storage & cache and do Clear Cache.
Now go to Settings - Battery Enable battery-draining apps and then press on Detect battery-draining apps. You should see Detect & Stop. Enable it and then disable it.
Restart your device and then see if it happens.
ishaan_gupta10
Another thing I noticed is My notifcation tray shows location on but it is off. Why my device is actong so wierd lol. spooky.
ronald1985
Community Legend I
ishaan.gupta10
https://us.v-cdn.net/6031231/uploads/MNABZKJ7WFSQ/2020-08-30-01-34-22.mp4
Yes that is weird indeed.
Can you go to settings - locations (while it's greyed out), does the recent app using location changes? From my understanding with locations, when it's turned off, it would be turned off completely.
Perform toggle on Airplane Mode to see if it turns off the location icon?
If the above doesn't work, does rebooting your device remove the location icon?
Also, do you remember how you got that to appear without turning on locations?
ishaan_gupta10
It got fixed after rebooting. Icon now gone. I dont remember how it got there. Now Ill check for the mapmyride soon when i try it out next
