BATTERY ISSUE (URGENT)
Not applicable
My ROG phone used to have like a day of normal usage like youtube and stuff and still had about 56% battery left. Now it gets from 59% to 44% in just 10 min while using only youtube and no background apps. I am monitoring my device battery from past 3 days and observed that my battery is charging extra fast (30w charger) than before. it fills up like 5% battery in just a min or less. I also keep my phone between 40-80% most of the time and still the battery life is depleted. What do i do? Is it covered in warranty? And also if i get a replacement product? Global version asus on android 10 beta 7.
LP_ASUS
Community Legend I
Perhaps you would like to join the community testing of the ROG Phone II battery that Anders is coordinating.
Ralph Christian
Just did a factory reset. ( Replaced Feb 1 ) 2 weeks used.
PC Mark is the only app installed.
ROG 2 Ultimate Edition.
PCmark work 2.0 benchmark battery.
6hrs
Xmode on
WiFi on
120hz
100% brightness
PC Mark 2.0 Benchmark Batter Life 2.0 6hrs only.
If your battery is significantly degraded, the repair center will replace it in warranty for you.
