05-10-2020 11:27 PM
05-19-2020 09:47 AM
09-19-2020 12:30 AM
09-19-2020 12:55 AM
anggazettinoHi, yes still no solution. I tried a lot of different routers including Asus router. Reset everything and the problem still there. 5Ghz connection capped at 2mbps. I even upgraded my isp speeds, still no solution. My cheaper android phone have proper speed on 5Ghz. Tested all the routers and different locations still have no solution. All the tested routers also tested on my ROG laptop and its ok. I hope there will be a proper solution soon from ASUS. We've been waiting since May this year.I have the same problem
My Asus ROG 2 download speed is capped at 2Mbps when using 5ghz wifi.
Still no solution?
09-19-2020 05:30 AM
09-19-2020 06:17 AM
kchinnavigneshrajaYeah, it wasn't an issue at first. Then there was a push OTA update. I forgot which one was it then the issue exist. One of the moderator here advised us to update to the latest firmware. But, it didn't fix the problem.My ROG Phone 2 has no issues or speed caps with 5Ghz connection. Btw I'm on Android 9.
Maybe the issue is device specific?
