Air trigger problem
mr_strange
Rising Star II
When I'm using air trigger, i found out that even when i press the screen or back side near the air trigger, it gets triggered. DowsDoes anyone face the same problem ( sensitivity is set to around 1 to 3. Please help me because if I'm only having this problem, i can replace it. Thank you
71 REPLIES 71
mr_strange
Rising Star II
bunnyfastard
Same issue. Please let me know guys if this is really a hardware issue. Already gave my phone to the service centre but they couldn't fix it either.
Attaching a video for reference.
Let me know if you guys have the same issue.
https://us.v-cdn.net/6031231/uploads/029/JH5QX45JBSXV.mp4
Initially i had this problem in left air trigger same as urs.it was shifted to right side with the new update. But now it's gone. Like reduced.but i have other issues
LP_ASUS
Community Legend I
If you are able to trigger the Air Trigger when touching the back of the phone, this is most likely a hardware issue and I recommend contacting an ASUS service center.
The separate unresponsive Air Trigger issue should have been resolved with the latest firmware update.
mr_strange
Rising Star II
LP_ASUS
But it just shifted from left trigger to right after the update. My left trigger works perfectly now. So i think it's not hardware issue. And many people are having this issue
LP_ASUS
Community Legend I
mr.strange
https://zentalk.asus.com/en/discussion/comment/33537#Comment_33537
So before your left trigger was faulty, and after the latest update you are seeing the same behavior but on the opposite Air Trigger?
ROGuser
LP_ASUS
https://zentalk.asus.com/en/discussion/comment/33569#Comment_33569
I guess that is what he is trying to say over his last 2 posts
