.49 High Battery Consumption
ah_shun_90
Model Name: Rog Phone 2
Firmware Version: latest
Rooted or not: not rooted
Frequency of Occurrence: after both update
High consumption of battery after latest .49 update. Please help
8 REPLIES 8
Gaurav_ROGII
Rising Star I
No one is replying, I also posted 2 discussions but didn't got the response , I factory reseted for 2 times but still the cpu's temperature is high and device shut downs automatically.
Anders_ASUS
Hall of Fame III
ah_shun_90
  1. Model Name: Rog Phone 2
  2. Firmware Version: latest
  3. Rooted or not: not rooted
  4. Frequency of Occurrence: after both update
Are you still experiencing this?
Gaurav ROGII
If device shut down is involved, then you have a hardware issue and need to contact your local support
nationkid
Rising Star II
I have to agree on this topic. .49 solved the heat issue and battery drain on the battery from the cpu but I have had to charge my phone twice a day now compared to pre .49 (battery levels 40%-70) nothing else has changed, same apps, same useage and also charging on a slow charger.
Gaurav_ROGII
Rising Star I
Anders_ASUS
https://zentalk.asus.com/en/discussion/36895/49-high-battery-consumption
https://zentalk.asus.com/en/discussion/comment/120318#Comment_120318
yes it is still the same, but I don't know how it became hardware problem for some while some are not facing this!! has 0.47 update has destroyed our motherboards?
@Anders_ASUS
