05-25-2024 01:12 AM
Model Name: Asus Rog Phone 8
Firmware Version: 34.1420.1420.387
Rooted or not: not
Frequency of Occurrence: all the time
signal not stable, lost connection and ping (specially during play games) between switching network 3G/4G/5G
please help
Solved! Go to Solution.
05-26-2024 10:18 PM
You might have to debug what causes it using a cell connection monitor app.
Cell towers may kick off phones with a weak signal when congestion is high. You may also get kicked off if your phone is using invalid channel aggregations because it was made for a different region (or is programmed wrong). For example, T-Mobile will kick off an NSA 5G phone if it does nonsense like mixing a short-range LTE band with a long-range 5G band. That combo requires SA 5G.
05-26-2024 10:18 PM
