Rog phone 8 pro air trigger problem!
Blessedbe
Hi! What's going on with air triggers? Why are they so bad at pinching? In the video, they are clamped, and not just clicking! Is it a mechanism failure or a firmware bug? Rog phone 8 pro, update: ww_34.1420.1420.218
1 ACCEPTED SOLUTION
Accepted Solutions
MrPens
Airtriggers from Asus 8 is bad, i did gived back to the company where i did buy. in Netherland you can give back to the company in 14 days. Already buy the older version from asus and works good.
8 REPLIES 8
Vikas_Rathore
Rising Star II
Are they working fine before update?
I don't know! It was automatically updated out of the box...
Vikas_Rathore
Rising Star II
Are air trigger working fine before you updated your phone with 218 version.
MrPens
