Notification problem
OmniverseHero
Why does the notification still doesn't work on rog 8 pro  common it's been so long. Like it doesn't  pop up or doesn't  even show in the top .I mean it's fine if some apps wasn't showing the notification but no literally not even single apps pops ups notifications at top .Isn't there any way to fix these problem .Like I have look every settings everything there is nothing we can do cause it's the system problem I guess.will we get new system update  or get any thing to fix this problem???
1 ACCEPTED SOLUTION
Accepted Solutions
Thank you for the solution sir but I prefer not to do factory reset it is fine to again complete all your settings but the 200 games and their 670 Gb data ☠️☠️☠️ no that's  kind of scary ,Any ways thanks to @Koudmaker I have successfully flashed 2 latest firmware and was able to get latest features and android 15 updates on my rog 8 pro .And thank you for giving me suggestions @Mattias_ASUS  .
I appreciate both of your help.
Tell me if there is any ways to fix this notification problems in the upcoming future thank you 🙏.
No way At last I found the problem myself and solved myself too lol.
I used to love locking apps because I like to keep privacy but since rog have their own inbuilt apps lock system I locked all the apps but who would have thought that locking apps can lock/block their notifications too when I searched all settings , developer settings I got nothing but at last I decided to check my home settings and when I unlock all the apps that I locked all the notification popup like crazy Any ways thanks for looking out for my question @Koudmaker  and @Mattias_ASUS  much appreciated.
Ohh there is a option too show or hide notifications even after locking the apps   sheesh thank got they already have this option  or I would have to used other third party apps any ways .
THANK YOU..🙏
14 REPLIES 14
Koudmaker
Zen Master I
Can you check the next option for us;
Settings >> Apps and Notifications >> permissions manager >> Notifications.
There is where you can see all the apps that have permission to send a notification.
Ya I did everything but still the notification doesn't pop up not even from single app . I guess it's the system problem here cannot do anything until they fix these with new system update.
I don't have any problems with notifications i did works since the release. So there is 100% something disabled in the settings.
Maybe check the permissions of the Asus launcher.
No sister I checked everything what more do you want me to check I even checked in developer options nothing is turned off for notification.
