Higher battery drain on V35.1210.1420.78 Android 15.
Koudmaker
Zen Master I
So after using the Android 15 update for 2 weeks the battery life is still terrible forcing me to use ultra durable mode to reach the end of the day with 20% left. Normal i was using Dynamic mode and ended the day with 40% left. ( yes my device was running the Beta version before and the latest update V35.1210.1420.78 was also a beta that got s stable release).
I did try to empty the phone and let is recalibrate it and re learn my usage but no succes. So there is 100% something faulty about that update because normal it wil sort it self put after a week.
Other things are maybe the background app monitoring is broken.
10 REPLIES 10
Mattias_ASUS
Hello @Koudmaker
Does this happen even after doing a reset?
I wonder if you could provide a log with the battery drain, so that the dev team can look into what could be draining the battery.
You can follow the instructions down below and please feel free to send me a DM with the link when you are done.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
I already found out what is the problem. It has something to do with the adaptive refresh rate. The phone stays longer at higher refresh rate even when there is no action on the screen. But i keep still monitoring because found also out the battery drain on the apps i daily use are alot higher. So it can also be developers poor optimizations for Android 15.
Thanks for the info @Koudmaker
Forwarding the adaptive refresh rate info to the devs, hopefully they can see something, let me know if you find something else.
I found a new bug with the weather widget. It happen sometimes that it can't load it.
But after a phone reboot it does temporary fixed it self.
michal_mateja19
A14 - i have SOT 8-9h
A15 - 6h !!!
