battery consumption while idle is very crazy and not normal.
alifsyera
After updating to version 35.1210.1420.78, my battery dropped 45% in just 4 hours while I was sleeping. This issue had occurred a few times before the update, but after updating, it happens much more frequently.
ASUS, what have you done in this update? All I've noticed is that all apps now run at 120Hz, Fingerprint AppLock is much worse, and overall performance feels worse.
Is it just me, or has anyone else experienced this?
Here's is the proof:
Koudmaker
Rising Star II
You are having something running in the background for sure. Mine idle drain is only around 4%.
yeah, but it's just google chrome and spotify doing nothing and it shouldn't be this crazy
Hello @alifsyera
It could be that there might be some leftover code working in the background after the update, this can happen after a new Android update.
The easiest solution would be doing a factory reset and having a fresh new Android 15 boot, battery drain is pretty common after a new Android version, but that does seem to be excessive.
