Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
198 REPLIES 198
Cheddus
Yes it is now only in this pro edition version(24 g/1To).
Not in other versions
GarbeGD
is AeroActive Cooler X worth it for 50€?
Yes its worth it, it works very well for me the Phone never Overheats and i mean its the only one you can attach do it without needing a cable.
Cheddus
This problem solved for everyone?
