Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
Zцlц
Any update? The last update was only solving the cooler buttons. I am on 34.1420.1420.316
Zцlц
This is the most annoying thing I have ever experienced with a phone. Like wtf, it's a gaming phone and key features are failing.
I can only be upset on myself that I didn't read any reviews before buying. The real issue is that I feel I am getting scammed and robbed.
Scammed because I had the ROG6 and ROG7 before buying this new ROG8… Based on reviews at YT everything was good, then in my hand it failed big. Robbed because if the support is like this, not providing a fix in a reasonable time meanwhile I payed a lot to get it.
Will I buy the next ROG the 9? 🙂
I think its not their first time, I remembered my ROG2 has the same issue and ROG took the initiative to listen and gave updates to rectify issues. Compared to other brands that I've used (IE. legion1, Legion dual), those guys don't update at all. I returned back to ROG6, without any issue but ROG8 is giving me some memories of the pass experience.
But because they are very consistent with the updates and fixed while listening to us, I'd rather be on a platform that listens and fixes. That's just me tho, I hope you'll get the same experience as I do too.
subhadipdebnath
Guys. There is a plethora of tap and click modes in the air trigger settings. Not sure if it was there to start with and I did not notice or if this is new addition. But these features are amazing. The Touch(Shooting Assist) option looks great and might give more flexibility.
Request you all to check these options out of you have not discovered them yet. Totally worth it.
@Mattias_ASUS I totally love the Auto repeat tap option. But we need more options on number of taps per second. 4 is the max but its pretty slow for certain games.
