Air Trigger Issue in ROG 8 Pro
Vikas_Rathore
Rising Star II
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
231 REPLIES 231
The new AirTriggers are a clickable system and the team is still looking into how to make it better and improve them.
I believe that if one more update is done on the subject of triggers, because they are still a bit stuck, it will be complete... @Mattias_ASUS
Look into it faster and push out a hot fix for the triggers don't wait for a general fix update ,people are getting angry and impatient
Mattias_ASUS
Hello everyone!
I'm happy to announce that today we have released the new update 34.1420.1420.316 in which we added a new lower pressure threshold for the triggers called Ultra Minimum which makes it easier to press the AirTriggers, to do this you can go to Armoury Crate, select AirTriggers and go to the Tap Settings.
Along with this update, we are also improving other things such as the AeroActive Cooler, audio quality and an improved gaming experience.
【Release Note】
  1. Updated Android security patch to 2024-02-01
  2. Improved system performance and stability
  3. Improved gaming experience
  4. Improved AeroActive Cooler X stability
  5. Optimized system UI/UX
  6. Improved audio quality
  7. Improved experience of AirTriggers
The update is rolling out right now and should appear on devices in the coming days, if you don't see it then you can go to Settings > System > System update and check if you have an update pending.
It's still having some issues with the update...But not like before
