02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
02-06-2024 05:43 AM
Hi! I replied in the other thread regarding the same issue.
03-06-2024 12:56 AM
Hello, which phone do you recomend for its best triggers. I am thinking of changing my black shark 5 but triggers for me is the most important issue.
03-11-2024 09:56 AM
Mine same issue board replaced
02-06-2024 08:52 AM
Dear moderator we know how to use it because we are using this from the past 4-5 year of previous Phone.
Just i want to clear that it can be fix with low pressure and with more stability.
Asus can do it cause they already putted a pressure setting on button. If they able to do it with less pressure on trigger with an update im sure this will be fix.
Right now the Air Triggers required double the Pressure then the Previous Phone we were using .
These Triggers are unstable also they don't work with consistency. These area can be fix with software update.
02-08-2024 05:48 AM
Hi
The latest update release should bring some improvements to the AirTriggers and in an upcoming update we will be introducing a new sensitivity level.
