02-05-2024 12:44 PM
Air trigger pressure are much higher and not stable at all even you set lowest on Pressure button setting from AC . Sometime it work and sometime doesn't. When you connect Aero Active cooler X the air trigger are less stable and required more pressure. ASUS should fix this for the all gamers who all love ROG Phone Series. Else they will never buy upcoming ROG series Phone in future.
I think The Pressure on air trigger should be fix with less Force on trigger with more stability. The Problem will be sort out easily.
I hope Asus ROG Phone Team will read my comment and will sort out in next update and reply to me.
Please Asus Fix this issue. Eveyone facing this issue who bought ROG 8 Pro.
In other feature the phone is very good .
Solved! Go to Solution.
03-02-2024 03:44 PM - edited 03-02-2024 03:44 PM
With this update there's a slightly improvement and kudos for that. I hope u find the best solution for this. Everything's fine on my phone, its just the air trigger pressure nothing else. But thanks for the update it improves abit. Used in like 4 matches and works fine with me it'll be better if u make it 100% touch instead of by pressure. One more thing please at least include the details on each update so we know what's the changes from old to new update.
03-04-2024 05:07 AM
New problem discovered today. If you press the headphone jack the right trigger actuates😂
@Mattias_ASUS I think its time that you start doing RMA and replace the clickable buttons with time tested ultrasonic buttons. We are really frustrated with this
03-01-2024 06:48 AM
@Mattias_ASUS Still there is issue while holding the the triggers. Please look into this .
Cooler Button issue resolved.
Airtrigger are still same as previously felt just little improvement in pressure only i felt need stability in trigger.
If you hold trigger and press in some area ( back of the phone) or accidentally your another finger touched to back of the phone trigger suddenly stopped or you can say released from the click.
Kindly look into this forward it to dev.
03-01-2024 07:16 AM
The problem is that if we use the air triggers on their own, they work correctly.
But the big fault occurs as soon as we touch or hold pressure elsewhere on the screen or the back of the phone.as if the pressure sensor was on the whole smartphone and not just on the edge of the smartphone.
The biggest problem is the left air triggers in my rgphone 8 pro
03-01-2024 07:36 AM
This is my fourth trigger phone, and my third rogphone. It's the first time I've seen a trigger that does this.
Too bad otherwise it's an excellent smartphone.
It's strange that more people don't complain about it.
Maybe it's due to a failed series on the smartphone or on the triggers.
