Noise cancelling on rog 7 doesn't work.
Sam1991
Rising Star II
Hi everyone,
I was wondering if someone could tell me how to enable noise cancellation on my ROG phone 7. I searched my phone settings but no luck so far.  I've had many complains about background noise while talking to others . I believe noise cancellation on my phone doesn't work for some unknown reasons or not functioning the way it's supposed to.
I also found out that , Asus rolled out some kind of AI Noise cancellation for Asus ROG phone 8 . Will that feature come to ROG phone 7 as well?
Thanks in advance.
Mattias_ASUS
Hi!
ROG 7 does have a noise cancellation feature built in, if the phone is now being used with the loudspeaker then the noise cancelling might not be as effective.
