05-25-2024 10:40 PM
I connected my ethernet cable to a usb c adapter but it doesn't provide internet. It works on all other phones I have tested but not my ROG 7. Does it not work for anyone or is there a setting I'm missing?
a month ago
Do a factory reset and try again. Maybe it will fix it. I think the problem may be with Android 14, because with 13 I have no problems with it, and I play only with wired connection. If it will continue, then I would report it to customer service
a month ago
I'm not factory resetting to fix it but thanks. It shouldn't ever break in the first place and also I don't need it, I was just testing it. Nice to know it works on a13.
a month ago
It works but the side port doesn't make good connections.
3 weeks ago
I am also facing the same problem, have you found a solution to this?
