a week ago
a week ago
Hello @EineLeine
In certain cases AIDA64 does not show correctly the battery status, this is confirmed by a mod in their forum.
Which firmware are you on?
And could you maybe create a log so that the dev team can see what could be causing your issue? Just recreate the issue by charging it to max capacity and please send me a PM with the link when you are done.
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
