Wide Angle and Front Camera Problems ROG Phone 6
Greys
Model Name: Asus ROG Phone 6
The issue is that when I open the camera app, the front camera switch button doesn't show IP, so I can't use it at all. And the when I switch to the wide angle camera, it gives me a somewhat zoomed picture compared to the normal camera, instead of the very wide angle, and it is also extremely blurry.
Mattias_ASUS
Hello @Greys
I for this issue I would recommend contacting your closest ASUS Service Center so that they can take a look at your device.
https://www.asus.com/support/service-center-location/
I don't have any where I live.
The issue started happening a few updates ago.
