11-28-2023 01:28 AM
Can anyone share the first release build firmware android 12 for rog 6 global version? Please i just hate how android 13 perform on my rog 6, battery get worse and playing game sometime get spike lag
12-05-2023 08:36 AM
Hello
ROG Phone 6/6 Pro (AI2201) Software downgrade from Android 13 to target Image Version: WW-32.2810.2212.241 (Android 12) for WW/EU/RU/TW/IN versions.
※ Before you start the downgrade, please make sure all pictures, important data finished the backup.
The downgrade process will erase all data to be a new system. ASUS company would not be responsible for the risk of data loss.
Version Android 13 to Android 12
4.13 GB 2023/02/22
Steps of Update:
1. Download the firmware to internal storage.
2. Remove Google Account.
3. Pull down the quick setting list.
4. The system will pop up a message which detected a firmware update info.
5. Execute the downgrade firmware file.
* If you skip step 5, and you don't know how to trigger the downgrade process again. Please reboot the system, and the downgrade info will pop up again.
*How to know the device model?
Path: Settings->About-> Model number
Example: ASUS PadFone2
**How to know the device software version?
Path: Settings->About-> software information->Build number
Example: CHT_PadFone2-user-10.4.17.15-UpdateLauncher
*System upgrade may cause part of data missing, please backup your important data before system upgrading.
12-22-2023 05:05 PM
was any fix found for it?
12-22-2023 08:45 PM
What is your build version
12-22-2023 09:07 PM
WW_33.0610.2810.177
12-22-2023 11:15 PM
Its blocked
My info is since .172
