I need help with camera and loop
Sharuga
Im using an rog phone 6 but when I open up my camera it always restart and right now its on the stat boot loop. Now I dont even know how to fix it. It happen after I update my software
Namelessuser
change frimware it will fix camera reset (it will be back)
boot loop error is because new update
Mattias_ASUS
Hello @Sharuga
For this issue I would recommend you reaching out to your closest ASUS Service Center.
https://www.asus.com/support/service-center-location/
