11-22-2022 07:17 AM
12-09-2022 02:21 AM
12-09-2022 02:33 AM
12-09-2022 11:06 AM
12-09-2022 11:22 PM
FunBike31Yes, i did reset the usb tester before charging the phone. I did not understand the last part. You mean a picture at 0-5 percent and then at 50 and at 100 ?Do you reset the usb test before new capacity measurement?, I think so because on the majority of models the displayed capacity will increase each time but I have already seen models where the capacity was and remained at the same first measure.
Otherwise, your value corresponds, unfortunately, to the capacity of a single battery or to 50% of the 2 batteries, in the latter case the batteries would be dead, easy to diagnose, the discharge slope in use will drop sharply, for example 100, 90,80,70,60,50.0
A bit like your curve on screen but more violent.
You should post a Screen of the usb test at 0-5% (at the start of charging) with hours/minutes, then a 2nd at 50% + hh:mm and a 3rd at the end of charging always with hh:mm, you go to the service center with the screens and you make them eat the ROG 5
12-10-2022 03:30 AM
vamsikrisnaYes, to see the progress and the charging time, but hey, that won't fix it and given the incompetence of your service center as well as the honesty strongly questioned *, a 3rd intervention does not seem to be the right one solution, put pressure on ASUS to obtain a standard exchange.https://zentalk.asus.com/en/discussion/comment/241004#Comment_241004
