06-12-2021 03:56 PM
06-17-2021 04:22 AM
Reaperzwolf@Reaperzwolf I did not return the phone as resetting the phone as per @thejus44's suggestion did improve the battery life.https://zentalk.asus.com/en/discussion/comment/171757#Comment_171757
You should tell them that none of my business if the problem is with the phone you need to replace it as per your T&C, and if you can't refund back the money.
So if they give you back the money,you can reorder a new one.
06-17-2021 05:33 AM
06-17-2021 06:22 AM
thejus44Compared to the 2 and 3 the split battery is to blame as well. Because the efficiency is reduced compared to a single large battery. Plus, the split batteries arent even 3000 mAh (misleading advertising), they are 2885mAh each, making the phone a 5770mAh battery phone.@Anna-Kin that's pretty great to hear! I've heard from other people that their ROG phone 2&3 battery health sustained for plenty of time, and still sustains, actually. If the battery health goes down then I don't think it'll be a problem to go to an asus service center and ask them to replace the battery. I did disable automatic software updates, so I think it would be wise for you to do so as well, and maybe come back to the forum to see if any asus updates are making it better or worse, and then update based on that.
06-17-2021 11:05 AM
06-17-2021 11:45 AM
