Heating problem
Moxy
Model Name: Rog phone 5
Firmware Version: .151
Rooted or not: no root
Frequency of Occurrence:
A temporary solution to heating the phone in play? When will an update be released that will fix this? Help me please
6 REPLIES 6
Danishblunt
Hall of Fame I
Lord_Messi
No solution for now
It's easily hot when use it for daily not mention for gaming
For now we can hope for the next update they allow this phone to run at 300 MHz because if you use use dynamic and ultra durable mode it lock your cpu speed at 845 MHz and if you use advanced mode lv 1 it lock your cpu at 1.31 GHz. That's one of the reason why this phone so hot because it use high cpu clock even at idle
This has nothing to do with clockspeed and everything to do with how the cooling is build on the phone. Even if you limit the CPU to 300mhz, which isnt possible as the minimum is 800ish mhz, it wouldnt make the phone less cool because the phone is designed to be the heatsink. All a lowering of the clockspeed would achieve is that it would take slightly longer for the phone to heat up from a powered off state.
@B 4 C 2 D 0 As already mentioned in another topic, you don't have to worries, those temperatures are very well within normal operation.
FunBike31
Community Legend I
Although the rog 5 does not have the best cooling system all the temperatures seen in this thread are normal.
For the temperatures quoted "especially at rest" without indicating the ambient temperature or how the device is installed / supported, you cannot make a comparison.
